Data not working
modugnot
Hi,
I just joined Public mobile yesterday and talk and text seems to be working (I have a new number). Data is NOT working though. I have the correct APN setting. I am using an iphone 11. I've still not received any confirmation email for activation also. Why is talk and text working but not data?
T.
UPDATE:
Data is now working. All I had to do was turn off "roaming". Now everything works! Thanks everyone!
13 REPLIES 13
@modugnot wrote:
This actually makes sense however I don't see any options for an update in the section you've mentioned.
Which iPhone you have and what OS is that on?
I guess connecting to the computer for update is the easiest way..
 @modugnot : I'm pretty sure it's almost always required to connect via USB to itunes to do this checking for updates. But I'm not an Apple guy.
iTunes might be called something else now too.
On your iPhone, go to Settings > Cellular > Cellular Data Options and tap Enable LTE or Settings > Mobile Data and tap Enable LTE. try it please.
visit HERE
make sure Update your iPhone ios visit HERE
modugnot
@modugnot  Look like you need your carrier profile download
Make sure that your device is connected to Wi-Fi or a cellular network.
Tap Settings > General > About.
Follow the onscreen instructions to install your carrier update.
Or you can connect to phone to the computer and update with iTune
darlicious
@modugnot
If you continue to have issues after any software updates and syncing to iTunes read this thread to change certain apple address settings etc....
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/td-p/323118/highligh...
@modugnot wrote:
Hi,
T.
Hi @modugnot ,
I will ask, because it has happened before...is your Data turn on?
Also, try:
  • a RESET of your Network Settings on you iphone 11.
  • Toggle into airplane mode for a few minutes, than back to regular mode.
If still issues, are you able to try your SIM into another compatible Public Mobile phone to see if data works then?
Only one way to you fix it explanation to moderator Team and the are nice service the will 100% help you
you have to Submit a ticket to a moderator, the will fix it 100%
don't worry about it my dear Good luck with the solution.
your welcome to public mobile
with a Beautiful Service
you will be very happy
Good Luck
 @modugnot : Can you connect via USB to a computer running itunes and check for any updates.
modugnot
Nope. Still doesn't work. I've submitted a ticket. I hope I can get my money back for the plan if it's not going to work.
If your iPhone  cellular data is not working, you can try powering down your phone and turning it back on, checking for carrier or system updates, turning cellular data or airplane mode off and on again, and, Reset your Network Settings, as the last resort, performing a factory reset your iPhone.
modugnot
That's super confusing! I did all the apn stuff and reset the phone. Data is still not working.
do one thing take your SIM card out and waiting for a minute and put it back and do rebooting your phone - This one is quick and simple. Make sure your phone is off before removing and reinserting its SIM card.
Remove your phone’s battery - Some phones have removable batteries. Sometimes removing and reinserting the battery can fix certain issues. Just make sure your phone is off before you do this.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Ensure you have the correct APN settings by visiting HERE.
Changing APN Settings On An IPhone
click HERE
Changing APN Settings On Android Phones
click HERE
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is go through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your DATA is on.
if you still have the issue you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • or you can send a private message to Moderator_Team by Click here
  • You’ll need to be logged in to your Community account for the link to work.
  • In your message put it, please include.
  • your account number,
  • your phone number,
  • your account PIN,
  • explanation to them nice Team and nice service
      Good Luck
