07-10-2020 07:04 PM - edited 01-05-2022 12:03 PM
I haven’t had to use my data yet because I’ve been in quarantine and haven’t need it cause I’m home on wifi. But I’m working now and I went to use my data (the first time since switching to public mobile) and the data doesn’t work. I’m just wondering how to set up me data? I have an iPhone 7. Thanks
07-12-2020 10:35 PM
@Marareesor18 wrote:My data still isn’t working, and I can’t figure out how to start a ticket. Sorry I’m terrible with technology.
Send a private message to the Moderators by clicking here
07-12-2020 10:29 PM
07-10-2020 08:25 PM
@Marareesor18 It should say public mobile xx.x. where xx.x is the version number.
07-10-2020 08:04 PM
@Marareesor18 is your data working yet?
If it is still not working click on this link:
https://publicmobile.ca.ada.support/chat/
Say data not working then contact us. Support will start a ticket and try to help you out within 24 to 48 hours usually quicker though.
cheers
Naepalm
07-10-2020 08:02 PM
Ok what should it say? 😄
07-10-2020 07:44 PM
Note: merged a duplicate thread into this one.
07-10-2020 07:40 PM - edited 07-10-2020 08:20 PM
07-10-2020 07:28 PM
@Marareesor18 can you navigate to settings>cellular and make sure cellular data is enabled
07-10-2020 07:19 PM - edited 07-10-2020 07:25 PM
@Marareesor18 did you log into your self service account and see if you have data? Thanks. Stay safe. If you dont have any, disable Imessage, enable data, sms amd mms and try sending a message. Imessage willnot work if wifi or data isn't available.
Here is an article on the differemces between the 2 https://www.xfinity.com/hub/mobile/difference-between-imessages-and-sms-messages
07-10-2020 07:17 PM
It still doesn’t seem to work.
07-10-2020 07:11 PM
@computergeek541 , @Luddite47 , oracles duplicate post, please merge. Thanks.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Data-not-working/m-p/566173#M73987
07-10-2020 07:10 PM
This is what I found on previous post:
iPhone
Step 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Step 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
07-10-2020 07:10 PM
@Marareesor18 @Hi go into settings and do a network reset
07-10-2020 07:09 PM - edited 07-10-2020 07:09 PM
Log into your self service account and check to see if you have any data left @Marareesor18 . Imessage uses data if not on wifi. If you do, do a network reset and restart your phone. If it fails to do so automatically.
Reset your Network Settings. Tap Settings > General > Reset > Reset Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Enable data, sms and mms to send and receive from Android phones. Stay safe.
07-10-2020 07:05 PM
I haven’t had to use my data yet because I’ve been in quarantine and haven’t needed it cause I’m home on wifi. But I’m working now and I went to use my data (the first time since switching to public mobile) and the data doesn’t work. I’m just wondering how to set up my data? I have an iPhone 7. Thanks
