Reply
Highlighted
Re: Data not working.
@z10user4 wrote:
@isabellelabelle wrote:
@z10user4
 its a 4.4.2
is that make sence?
Well how 'bout that...that's the same one I'm looking at. Although mine is not stock.
Settings/Mobile network/Preferred network type. See what all you have in there.
@z10user4
i only see settings/mobile network/ then i see mobile data
                                                       data roaming
                                                       access point names
                                                       network mode
                                                       network operators
Highlighted
Ok, just going to try to find some info on it.
In the meantime try these even if you have done it before. Ask if you do not know how to do it.
- are you able to do an update, probably not because of the age of the version.
- switch airplane mode on then off,
- reset network settings
- Turn phone off - remove sim - turn phone on - let it find no service - turn phone off - insert sim then turn phone on
Highlighted
@z10user4
 its a 4.4.2
is that make sence?
@z10user4
                                                       data roaming
                                                       access point names
                                                       network mode
                                                       network operators
Waht is under Network Mode?
Highlighted
@stonechucker wrote:
@isabellelabelle, can you find your phone on This page and check your APN settings again?
@stonechuckeromg dude!!!
ITS A BREAKING NEWS...ITS WORKING..MY DATA IS WORKING GUYS...
Highlighted
I am so happy to hear it. Do you know what did it?
EDIT: With that being said your MMS (texting pictures) should be working too!
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
Highlighted
@krazykiwithank you yes i went here
https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-s-duos-3
and follow the instruction..i thought i did before but not sure what i did different.
thank you so much guys for all your effort to try to solve this issue.
@stonechuckerthank you for the link my friend it worked.
@Moderator_Team
shame on you for not helping me..
Highlighted
Hey I just want to thanks everyone who tried to help me out with this issue.
It took over an hour to find the problem 1 minute to fix. The moderator should be a bit quicker to reply to messages. anyhow...im going home now..finally
Hope you have a great nite.
thank you so much
Highlighted
thank you so much
You are welcome, and remember to come here first when looking for answers. The community is full of knowledgeable people.
Highlighted
@isabellelabelle, glad you were able to find assistance from my shared link.  Welcome to Public Mobile.
Maybe next Time you can reference the actual post that resolved your issue.
Highlighted
I am not sure what you mean by reference but I do believe in their reply they credited your response ( the one with the link). Was there something else?
