Data not working
Stovetop_24
I bought the US Roaming Talk-and-Text add-on and the 1GB of data add-on (the $30 one) before heading down to the states (Texas) on vacation. Now that I'm here, I've tried turning on the data so that I can use Lyft but it's not working. The talk and text works, and I've tried to use other apps on data but it doesn't work for any of them. How do I fix this?
7 REPLIES 7
srlawren
@Qtips2016 they may or may not also have an APN issue, but @Effort has identified the main cause of this issue--there is no $30 1GB US Roaming add-on; the $30 1 GB add-on can only be used while in Canada.
Qtips2016
I think the issue is that OP added Data to his/her cell phone service for the very first time.  He/She would probably need to manually add the APN settings which can be found here on this link:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
Step by Step APN configuration
Step1:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Windows
Windows 8 Step 1 Settings > cellular > Add or Edit internet APN
iPhone
Click here
Step 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Leave blank
APN type: Leave blank
Step 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
Effort
@Stovetop_24 wrote:
Of course I did.
On the bright side, you have 1GB of data when you come back that will carry over month to month and be there when you really need it!
Stovetop_24
Of course I did.
Effort
The $30 1GB is for in Canada only. There is also a US only 1GB for $20. You bought the wrong add-on.
132YJpf
Stovetop_24
I did not have any data on my plan before, I got the add-on specifically so I could use Lyft while I was here
@Stovetop_24, Did you have data working in Canada?
