Data add on
Domina
How do I add on to my data? I have purchased $15.00 to add on 1GB data.
popping
Login to your self-serve account.
If you have $15 or more available fund in your account, you have not done the second step yet.  Buy the add-on with the fund in your account.
After add-on purchase, check your the 1GB data usage line on your overage page to monitor your usage.  Later, if you don't see the data usage line, you had use all your add-on data.
@Domina heres a screenshot on adding the data add on. Stay safe.
geopublic
@Domina  Purchasing an add-on is a two step process:
  1. Purchase the add-on by adding funds to your account
  2. Use selfserve or dial 611 and add the add-on to your account
You still need to do step 2.
JoyLuck
Buying an add on is a 2 step process. You added the funds. Now go back into self service and make the purchase.
Here is a HDI:
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
