04-23-2019 11:21 PM - edited 01-05-2022 04:34 AM
I changed my plan on April 21st; it will go into effect April 30th. Since I did this the plans have changed. Will this effect what I agreed to on April 21st?
04-24-2019 05:34 PM - edited 04-24-2019 05:38 PM
@Anonymous wrote:Methinks @Luddite needs a vacation 🙂
All Oracles are now on vacation. We sometimes take some of the slower days off, especially during some weekends to recharge. Yesterday was a mess with account failures and everything.
04-24-2019 02:38 PM
@alicherise wrote:I changed my plan on April 21st; it will go into effect April 30th. Since I did this the plans have changed. Will this effect what I agreed to on April 21st?
@alicherise I know you already got your answer. I just thought I would add that this very question was addressed in the announcement that the promo plans were no longer being offered after midnight on the 22nd: https://productioncommunity.publicmobile.ca/t5/Announcements/Select-ready-made-plans-expiring-April-...
It states:
"If you’re interested in taking advantage of these ready-made plans while they’re still available, learn how you can set up a future-dated plan change on your next renewal date by clicking here. By doing so before April 22nd, your plan will automatically change to the plan that you choose on your next cycle."
04-24-2019 11:54 AM
04-24-2019 11:52 AM
@slash407 wrote:if u changed it before the due date u just shorted urself afew days of the service u paid for with the first plan purchase, that is all
Your response doesn't apply to the question.
04-23-2019 11:37 PM
@alicherise wrote:I understand this. My enquiry is I agreed on April 21st to 4.5 GB at 3G speed with an additional 500 mb if I prepay for $40 (to start on April 30th). On April 23rd the plans have changed to much less for the same price. Will I still get the 4.5 GB plus 500 mb I had requested on April 21st on April 30th???
Your plan will on April 30 will include 5GB, assuming you have autopay enabled, and assuming you scheduled that plan change on April 21st to take place on at the time your next renewal would have otherwise taken place on April 30th.
04-23-2019 11:36 PM
If you scheduled the plan change while the plan was available, yes.
04-23-2019 11:32 PM
Thanks
04-23-2019 11:31 PM
04-23-2019 11:26 PM
Yes
If you made your change of plans on April 21 to future date on April 30. Public mobile will honor that change even though the plans have changed after April 22.
04-23-2019 11:25 PM - edited 04-23-2019 11:26 PM
@alicherise , when making a plan change you have the option to have the change take place immediately or on the next renewal. If you chose immediately, then the plan changes right away and payment is due upon submitting the plan change. Past paid service is lost. If plan change on next renewal is selected, the plan will change on the renewal date with the amount due based on the newly selected plan. There is no loss in paid service. That is pretty much it, what you see is what you get, no surprises which is nice.
I should also add that for the future dated plan change option, there is opportunity to remove the plan change prior to it actually taking effect.
