Changing Plan
gcata76
Hi was wondering, if I was to change my  $40 plan to the $50 plan would I lose the referral credits I've earned. I would still keep the $2 Autopay but not too sure of the other. Thanks in advance for your help. It's greatly appreciated.
gcata76
Thanks for your help!
gcata76
Triguy
You would still keep your referral rewards.
  • If you’ve changed your plan prior to your current plan renewal date, you will receive your Reward credits after you have paid for the new plan, within approximately 24 hours. Rewards will be applied normally from then on.
GinYVR
@gcata76You will not loose any of your credits (referral or autopay).. they might be deferred until the next Autopay period though.
