08-02-2019 03:31 PM - edited 01-05-2022 06:15 AM
08-02-2019 03:50 PM
@trueje, if the lost phone toggle does not resolve the problem and you need to contact the moderators, they can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
08-02-2019 03:36 PM
@trueje wrote:Hi i changed my plan to the 15$ from 40$ and now only incoming calls and texts work. I just changed it at august 2nd at 2:20pm. Can a forum moderator take a look at my account please? Id like it to get working and if possible may i get a notification that its working?
@trueje Try the lost/stolen phone trick to see if it does a soft reset on your account to wake it up.
To report your phone stolen. Login to your selfserve account. Choose Plans and Add-ons tab. Choose the Lost/Stolen Phone tab. Choose Suspend Service tab. Wait 15 minutes. Report your phone found. Re-start you phone
08-02-2019 03:34 PM
you need to send private message if you need MOD help. Do you mean no data available? did you register auto pay and did you turn on the data on your phone?
