Reply
Highlighted
Re: Change plan
I had the same problem, and using a different browser did the trick for me.
Highlighted
Re: Change plan
Refresh the page and try again in a few minutes. Technical issues occur on most websites but correct themselves .If issue persists,contact a moderator by clicking ?, bottom right, and following instructions.
Highlighted
Moderator
Re: Change plan
Hi @chad2001
I will be happy to help. Before we get started, I will need you to access the link below and use SIMon and create a ticket.
https://www.publicmobile.ca/en/on/get-help
Bogdan_S
Highlighted
Re: Change plan
Best to be patient and renew a plan on the next renewal date to avoid issues like this. Click on "Change plan on next bill date" and everything should be fine. I used this method to change my plan and it was flawless. No mishaps. If this doesn't appeal to you, click on ?, bottom right, and follow instructions. A moderator should resolve the issue likely within several hours or a day.
Highlighted
Re: Change plan
Actually i tried to once and i did it successfully Thanks you guys for your  valuable feedback
Highlighted
Re: Change plan
I know that when you choose the plan you want you have to click [change plan now ]if its before your montly renewal date that you are trying to change your plan .if not the new plan will only be change on your montly renewal date.i hope this helps.
