08-12-2018 12:54 PM - edited 01-04-2022 06:44 PM
08-12-2018 01:19 PM - edited 08-12-2018 01:19 PM
@Dale123 Not sure about call waiting. It should be availalbe to all plans. Here is the knowledge article on call waiting.
Setting up the Public Mobile APN should allow you to connect to their data network, and use their network for MMS Messaging, even though you won't be able to web browse because you do not have a data plan. To Setup APN if you don't know how:
08-12-2018 01:14 PM - edited 08-12-2018 01:18 PM
@Dale123, when you say it works with another SIM, is that a Public mobile SIM? If it is not a PM SIM, then it is not a completely equivalent test. For PM picture messages to work, you must have data enabled on your phone (I assume this is already in place), and you must have the proper APN settings for Public Mobile. For APN settings, you can just go to the Public Mobile section of https://apn-canada.gishan.net/.
