Reply
Can't get internet to work
So I've sifted through several posts on here about internet not working. I set the parameters in settings that many people have posted, as well as restarting the phone. It is a samsung s7.
My sons phone has minimal internet, so I'm not highly concerned about him having access but I would like him to be able to send and receive pictures. Anyone run across this problem?
Re: Can't get internet to work
What plan do you have and what is included.   When is the renewal date?
@Jackiefargo  Can you post a screenshot of your apn settings?
To jump start the sim card, maybe you can try the phone  lost / found trick.
I have the same phone. I never touched the APN settings and it all works fine.
Settings/Connections/Mobile networks/Access Point Names - if you don't see one in there then touch ADD upper right.
I'll fill in what is set and ignore others
APN = sp.mb.com
MMSC = http://aliasredirect.net/proxy/mb/mmsc
MMS proxy = mmscproxy.mobility.ca
MMS port = 8799
MCC = 302
MNC = 220
APN type = default,mms,supl
APN protocol = IPv4
Mobile virtual network operator type = GID
Mobile virtual network operatorvalue = 4D
And of course turn on data:
Settings/Connections/Data usage/Mobile data to on
Can he access the internet via wifi? If so, I'd log into My account and see what it says regarding data, near the bottom of the main screen. If there's no data showing you should look at the usage. If he has the $15 plan, 250 can be used up pretty quick in a busy young life!
Yesterday I went live on Facebook for about 3 min total and used about 100mb that day.
I have a small plan also and I just cycle my data on and off when I need to text a picture under MMS (no data charges) or when I want to use the internet without wifi.
APN = sp.mb.com
MMS port = 8799
MCC = 302
MNC = 220
APN protocol = IPv4
Are you going to change your community name to match the phone you use?  Smiley Tongue
 Some of your info was different than what others have posted so I changed it.
Internet actually works! Thank you!
@Jackiefargo wrote:
@Jackiefargo
APN Type is not correct.
