11-28-2019 10:58 PM - edited 01-05-2022 08:12 AM
Hi, im on the $10 plan with 50 mins Canada wide calling.
starting yesterday, i cant make an outgoing call. the machine says i dont have an active long distance add-on, even though im trying to make a local call
incoming calls go straight to voicemail
thanks
11-28-2019 11:01 PM
@sumikazu wrote:Hi, im on the $10 plan with 50 mins Canada wide calling.
thanks
That means you've used up your 50 minutes. Remember it's 50 minutes total.
The $5 500 minute add-on is a terrific bargain for the $10 and $15 limited minute plans.
