05-25-2020 05:43 PM - edited 01-05-2022 10:54 AM
05-25-2020 07:21 PM
@popping wrote:Yes, you can do it as often as you like.
1. If you have a grandfathered plan, you may not get back your old plan back as it is no longer available.
@Etienne77 one important clarification here: there is no uncertainty here: if the plan you current are on is not longer listed on the plans page (https://www.publicmobile.ca/plans) at the time you want to switch back, you will not be able to get it back. Be warned.
05-25-2020 05:54 PM
@Etienne77 wrote:I have been with Public for a while now and would like to test a different plan for more data. Can I switch for 1 month and if I don't like it switch back the next month, no questions asked :D?
2. On the subject of getting your plan back, after your switch, you should schedule a plan change after your next renewal just to protect of old plan just in case your old plan was discontinued during the time you were on a different plan.
3. PM plans are prepaid plan. Therefore, there is not refund of the unused days if your change your plan immediately.
05-25-2020 05:46 PM - edited 05-25-2020 05:48 PM
You can test drive any of the offerings for 30 days or more. Make sure to select "Change on next Renewal date" when you select your next months choice.
Edit...you can change back as long as the plan you want to change back to is still available...otherwise select a different option.
