02-07-2017 12:23 PM - edited 01-04-2022 01:29 PM
I know I can call the UK and France (from Canada) as part of the Long Distance add-on plan.
My question is can I call or text the UK and France from the US as part of the US 10 day roaming add-on. And if so, what is the cost?
I am assuming you can call Canada from the US using the US 10 day roaming add-on!
Thanks
PS Sorry if this information is already available, but I looked, and can't find it.
02-07-2017 03:19 PM
One of the prepaid service i know is ttag.ca that allows you to call many countries with reasonable rates.
02-07-2017 02:46 PM
@RogerI you could work around it in a couple of possible ways:
1) Purchase some pre-paid long distance "calling cards" that feature a US or Canadian dial-in number and a reasonable $/min rate that you are comfortable with. These should be available from convenience stores, gas stations, supermarkets, etc. in Canada or the US. Probably cheaper to buy them in the US if you're only using them there. The call to the card's access number will be covered by your US Roaming add-ons (assuming you have chosen talk or one of the bundles that includes it).
2) Use a data-based service for the outbound calls. There are various options here, though most will require you to load a certain $ credits to call to Europe. These may end up being more $ and/or more hassle than just picking up a calling card though. Your mileage may vary. Also note if you go this route, your calls to Europe will eat up some of your data roaming bucket and are not covered by the unlimited talk minutes, so keep that in mind.
Overall I'd probably recommend #1 for calls to Europe.
02-07-2017 02:23 PM
Thanks for the quick reply. Kinder what I assumed.
But good to know about the International texting from the US. That will help my situation.
Roger
02-07-2017 02:18 PM
Would be nice IF PM could One day enable it
02-07-2017 01:39 PM
Haha! yes absolutely! 😛 😄
02-07-2017 01:34 PM
02-07-2017 01:31 PM
Hello guys,
Here are some answers to your questions:
1. If you have US text add-on (roaming), it is global text…so International is included.
2. U.S. Talk (roaming) is only Canada/U.S, not international.
3. The international long distance add-on is only a domestic package, features from domestic add-ons are not included while roaming.
I hope this helps!
Thanks,
Shazia
02-07-2017 12:38 PM
02-07-2017 12:36 PM
I am not 100% sure, I'd assume yes, for Txt only, calling, I am not certain IF it's possible
Perhaps a PM Mod can clarify
