12-29-2019 08:43 AM - edited 01-05-2022 08:45 AM
12-29-2019 10:42 PM
@leeandrew2020 wrote:Call across Canada plan but not able to make call within Canada (actually from Niagara falls to markham Ont)
Is it possible that you're connected to AT&T or T-Mobile on the other side of the border? If that's the case, you wouldn't be able to make any phone calls unless having roaming included in the plan or have a roaming add-on.
12-29-2019 09:04 AM
@leeandrew2020 Listen to @GR and use a (1) before the number or stay on the line and wait for the message to finish and your call will be connected.
12-29-2019 08:55 AM
@leeandrew2020 also try with putting 1 in front of the number you're dialling to
12-29-2019 08:46 AM
What happens? Do you get a recording? What's it say?
