Call Forward included?
Quick question ..
got the $25 unlimited Canada talk with 1gb plan
is Call Forward included?  If so.. is there any rule ? some plan (or at least used to) count talk time for forwrded call , although my unlimited talk should be ok..
thanks
Call forwarding is included with all talk unlimited talk packages, to another Canadian number.
The limited plans with talk can use it, but it will take minutes, and you will need LD minutes available to use it if you rely on forwarding to a number different than your voicemail box.
Province-wide plans can forward to a number in the same province the cell phone is connected (ie Ontario number on Cell in BC, to a BC number); with LD addon, can forward to any Canadian number.
LovesToPM
@softech
Heres some basic info
https://www.publicmobile.ca/en/bc/get-help/articles/call-forwarding
It seems the Call forwarding feature is limited to Canada.
You will find similar question asked here
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Call-forwarding/td-p/275961
@softech wrote:
Quick question ..
thanks
Call forwarding is available. No rules that I know of. Officially, the limited plans count.
Edit: come to think of it now...it might be restricted to Canada.
