Are incoming calls (but not picked up) considered a minute on the $10 plan?
koko777
Hi, I recently joined the $10 plan. I did some research and read that incoming calls ARE charged and considered minutes of your 50 limit. However, I'm wondering if I do not pick up the call will I still be charged the minute?
Example: I see my friend calling me. If I do not pick up, will that still be considered a minute used out of my 50?
QUESTION 2: as for outgoing calls, if I make a call and the other person does NOT pick up, is that still considered a minute used? Two situations:
1) I make a call and before I hit the voicemail I hang up (while it's still connecting), is that considered a minute?
2) I make a call and get the voicemail to leave a message (the connection is over), is that considered a minute?
Thanks.
@koko777 wrote:
@will13am ah because technically someone can call me 50 times, hit voicemail each time, and use all my mins? 😞
That is the problem.  You can control the outgoing but the incoming is sometimes out of your sphere of influence.  For me, the "CRA" calls me several times a month asking me to call them back.  They leave fairly long messages, some probably more than a minute long.  Having some cheap minutes is a convenience.
koko777
koko777
@MacMe Let's hope someone doesn't spam call me 50 times and uses all my minutes? :
will13am
@koko777, from a practicality perspective, the $10 is best paired with some add-on minutes.  You can only do so much to control the usage.  Having a backup is important to make sure the service doesn't stop suddenly.  The add-on minutes is fairly inexpensive and non expiring.
MacMe
If you don't answer a call, it will go to voicemail and yes you will be charged for it.
If you make a call and the other person does not pick up, you will not be charged for it.
If you get to the voicemail message, yes you will be charged a minute.
drmartin
Thanks.
If you don't answer you aren't charged.
As for question 2, I'm not sure if the billing starts when the phone rings or when the phone is answered.  Leaving a voicemail is definitely a connection/charged.
