Added US roaming talk but only get emergency message on my phone?
1433
Triguy
Make sure you add and purchase the US roaming add-on.  Also check your account under add-ons to make sure it is showing.  Also you need to enable roaming.
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
wangce2007
Try taking out you’re SIM card and putting it back
@1433  - Did you enable roaming on your phone?  Is your mobile network set to automatic?
EDIT:  PM uses AT&T & T-Mobile in the US.
dabr
Are you in the US currently?  Make sure your roaming is enabled and data too if you have a data package.
totalUser
What is your status?
Can you restart your phone?
If it didn't work Can you try sim in different phone?
