Reply
Highlighted
Account suspended
Account has been suspended and won't process credit card.
Highlighted
Re: Account suspended
If any of the info on your credit card changed recently, then you will need to update it
- change of address?
- replacement card?
Here is PM article on credit cards.
If you cannot use your card, you can also purchase payment vouchers.
Highlighted
Contact a moderator.  Use the ?Simon. Type in moderator and follow the prompts to get to one.
Highlighted
You can buy a topup voucher at Shell gas station and get your phone working ASAP.
Then, update your credit card info with the current card or use a new card.
Make sure the credit card address matches what is on your statment.
1. If you live in multi-unit building, don't use the unit # or apt#. Just use the building number.
2. If the postal code on your statement has a space in the middle, left the last digit out. PM check the first 6 characters of the postal code only including the middle space.
Highlighted
Nothing has changed.
Highlighted
Can you add $1 to your account?
If yes, autopay may not be working on your renewal date.
Create a moderator support ticket for help using the ? button at the right side bottom corner of this page.
Highlighted
@itsdevonklassen Are you able to make a manual payment?
If not, try removing the card and adding it back in again,
https://www.publicmobile.ca/en/qc/get-help/articles/update-or-remove-your-payment-card
Highlighted
Have removed the card and reapplied it, I have tried to make a manual payment. I have used Chrome incognito, Firefox and and Internet Explorer.
Highlighted
@itsdevonklassen  Well, if none of that worked, I think it's time to contact the Moderator team, either by using that question mark in the bottom, right corner of the page, or using this link:
Highlighted
Try restarting your computer and clearing your browser cache too.
You were able to register the card but it doesn't let you make a payment??
What is the error message you get?
