05-09-2018 12:09 PM - edited 01-04-2022 04:14 PM
I have been searching for detailed information about this plan, and it seems that there is no limit for data add on with this plan?
Is it possible? Or am I missing something?
Thanks.
05-09-2018 09:36 PM
Thanks very much for analyzing the situation for me ; )
05-09-2018 09:35 PM
Thanks very much for your suggestion.
I am mostly covered by WiFi and use very little data in a month. Not even like 100MB in a months. So I guess it could be a bargain for me if the 10$ plan support data add on for my little use.
By the way, I make almost no phone calls to Canadian numbers in a month. I wish I have someone to call in here ; )
05-09-2018 09:29 PM
Thanks very much. I am just making sure that this plan support data addons because the equivalent 10$ plan in other places like chatr does not allow data add on.
05-09-2018 12:53 PM
Data is not included with this plan. If you are looking for data you would need to purchase an add on.
05-09-2018 12:39 PM
@computergeek541 wrote:Data is not included with this plan. You can purchase it through an add-on, although I beleive in most cases, you'd be better off to take a different plan if you need data. The data add-on prices aren't that great, to be quite honest.
@dtrmcc I agree with @computergeek541 here. Add-on data is relatively quite expensive. So unless you plan to use very little of it, you may want to look at a plan that includes data. For example, for $30 you can get 30 days of unlimited Canada-wide calling (rather than just 50 minutes), unlimited international texting (rather than unlimited incoming and 50 outgoing) and 500MB of data at "3G" speed [still delivered via LTE, but throttled to 3Mbps]. This will likely be a significantly better value for your money than adding data add-on(s) to the $10 plan.
05-09-2018 12:16 PM
@dtrmcc wrote:I have been searching for detailed information about this plan, and it seems that there is no limit for data add on with this plan?
Thanks.
05-09-2018 12:15 PM
If you want data on this plan you will need to buy a top up.
200MB Data for $10 and 1GB Data for $30. Any unused data will roll over to your next cycle.
