10-17-2019 01:17 PM - edited 01-05-2022 07:36 AM
Hi there! I recently purchased the sim card to start the plan process for a 60$ plan that I noticed had data for 2G's in the states.
It's not there anymore now that I have the card, but I'm curious that if I get any of these plans. I'm looking at hte 40$, what charges will be racked up in the months that I am away?
I'm trying to getaway from rogers and they're outrageous billing and the 60$ seemed perfect.
So if I go for the 40$, what will be charged to me using my data?
If not I might just get the 50$ as I currently use data/wifi to speak to my american husband, and I could just call/text him in my journeys.
But uh, i lowkey wanna play pokemon go there so LMAO.
Anyway thank you for your time ❤️
10-17-2019 02:37 PM - edited 10-17-2019 02:38 PM
@psilo wrote:Hi there! I recently purchased the sim card to start the plan process for a 60$ plan that I noticed had data for 2G's in the states.
None of Public Mobile's current price plans include roaming. It's not a matter of what charges you'll rack up. The service won't work in the U.S. unless you add a roaming add-on.
The U.S. roaming options are all 10 days in duration. They are listed here: https://www.publicmobile.ca/en/bc/plans
I agree with the previous opinion that this could be quite expensive if using add-ons for 2 months and that you might as well sign up to a servcie from a U.S. preapid carrier. Since you haven't yet joined Public Mobile, it might be a good idea to wait until your come back to Canada to activate.
10-17-2019 02:21 PM
10-17-2019 01:22 PM
If you're planning to be in US for awhile, best to get a US sim and a cheap plan there. When you get home, you can start up with Public Mobile
at that time,
10-17-2019 01:21 PM - edited 10-17-2019 01:21 PM
The $40 plan has 4.5GB and bonus 500 MB if you setup autopay. PM is prepaid so once you deplete your data it stops then you need to either purchase an add-on for more data or wait until your next renewal date. You can purchase add-ons for us roaming which are valid for 10 days from purchase.
