01-22-2018 12:17 PM - edited 01-04-2022 03:22 PM
"90-day plan on Canada's largest mobile network"
What does this mean? That the plan only lasts 90 days? And then I have to get another plan?
02-23-2018 01:05 PM
Thank you wetcoaster
02-23-2018 11:27 AM - edited 02-23-2018 11:29 AM
@Ang99wrote:hey mimmo_L
What I was lloking for was the bar minimum in data for 90 days maybe 1 GB
Im always in WIFI zone. Thanks
The bare minimum would be going with a talk & text plan and adding the 1GB data add-on. It doesn't expire and is the most cost effective solution if you use less than 100 - 150 MB per month. (I still have abit left on mine after 10 months as I'm on WiFi at home and at work and rarely use the web outside of that.)
Next up would be a 90 day plan with 1.5GB of data, about 500MB per month (But it's yours to use as you please over the 90 days - you can use the full 1.5GB on the first day and have nothing left for the next 89 or 200MB the first month, 600MB the second, 700MB the third.)
Be aware that the data on a regular data plan can not be carried forward into the next billing cycle, the counter is set back to your (say 1.5GB) amount at renewal.
Make sure that you turn all data consumption off that's not absolutely necessary. Ie WiFi assist, updates, background data etc.
02-23-2018 10:50 AM
hey mimmo_L
02-22-2018 12:11 PM
hey @Ang99 i think there might have been some confusion in one of the posts
the plan is $180 for 15gb data for 90 day = $60 for 5gb / 30 days.
in the build your own plan you will fin it by selecting 90 days provincial calling global texting and 15gb lte.
how much data a month do you need?
selecting 3+3 gb @ 3g speed (2gb.month) costs 120$ of 6gb lte /90 costs $135
02-22-2018 11:56 AM
Hi there can you kindly direct me to the 5 GB LTE 90-day plan i cant seem to find it.
Thanks
02-22-2018 11:28 AM
hi plans at PM are for 30 or 90 days. the data you pre purchase is valid for the number of days so yes 5gb would be be valid for 90 days or approx 1.66gb / month. you can use all the 5gb on day 1 or on day 90 or spread it out between.
@Ang99wrote:Hello im considering switching to PM on the 90 day prepaid I live in Ontario Is it available
here? Am I understanding it correctly I can get 5 GB data for 90 days?
02-22-2018 11:23 AM
01-22-2018 02:23 PM
@Jaime Pleased you are seriously considering PM and doing some research. 👍 👍
I recommend you also read: https://productioncommunity.publicmobile.ca/t5/Getting-Started/BE-PREPARED/m-p/112014#M20827
And just in passing, I appreciate you marking my post as Solution but think NDesai actually gave the answer to your original questions. Not to worry though, he has has plenty of Solutions to his credit!
01-22-2018 02:08 PM
Cool, thanks. I meant 5 gigabytes of 4G LTE speed actually 😛
01-22-2018 01:52 PM - edited 01-22-2018 01:53 PM
5 GB data I believe.
BTW: if you turn on autopay you will save $6/90 days.
01-22-2018 12:52 PM - edited 01-22-2018 12:53 PM
It means you pay for entire 90 days as it's a prepaid service. The plan will keep renewing as long as you keep that plan.
BTW, it's 4G LTE. We are far away from 5G 😞
