11-01-2019 02:29 PM - edited 01-05-2022 07:49 AM
I'm in the states. My phone switched over to t-mobile and I've shut the phone off and on and my texts and data are NOT working! This is frustrating to say the least. Yes it shows the add on under my plan
11-20-2021 01:26 AM
oh no.. it's another of those ppl started replying from an old thread.. sorry.. too late at night.. should go sleep ..
11-20-2021 01:21 AM
Uh @softech?? : That was 2 years ago. 🙂
11-20-2021 01:13 AM
@jluong9 wrote:Maybe you could try a hard reset on your phone then manually selecting a carrier. If it really comes down to it you could try to reset your network settings.
hard reset a phone because roaming is not working? or you just meant a reboot?
if you hard reset a phone, you don't need to network reset any more.. everything starting fresh already..
11-20-2021 01:07 AM - edited 11-20-2021 01:08 AM
@Bertie1 : Did you figure something out or is there a question?
11-19-2021 11:19 PM
11-04-2019 08:12 PM
Thank you! I had already cycled phone on and off however I didn't search out a provider manually, after I did that and jumped down to AT&T it worked!!
11-04-2019 08:11 PM
Yes I did
11-02-2019 11:32 PM
Maybe you could try a hard reset on your phone then manually selecting a carrier. If it really comes down to it you could try to reset your network settings. However, that would reset all your saved wifi passwords. I do find it that it works sometimes. Hopefully you don't have to go there though.
11-01-2019 04:33 PM - edited 11-01-2019 04:36 PM
@LoreckAvery wrote:Yes roaming is on. It was hooked up to t-mobile now switched to at&t. I seem to be able to use data but not send texts
Log into My Account and look in Data & Add-ons...do you see the 10 Day US Roaming add-on ? When you bought it, did you buy the talk/text/data package ? Is the talk and data now working ?
11-01-2019 03:36 PM
Maybe try powering off your phone and removing the SIM, wait 5 mins and then re-insert and restart your phone.
You can also try the lost/stolen trick, log into your account, select plans/add-ons tab, report phone lost, suspend service, log out and wait 5 mins. Log back in and report phone found and resume service. Restart phone. This does a soft reset of your account.
If nothing helps submit a ticket via SIMon. Good luck.
11-01-2019 03:30 PM
11-01-2019 02:48 PM
Hi there @LoreckAvery,
Did you tried to manually search the network? Usually, you can find this under Settings -> Connections -> Mobile Networks--> Network Operators.
Most of the time, it's the first network that appears in that list that you need to connect to.
Try as well to do a power cycle. Do not forget to turn on the roaming option from your phone settings.
If this does not work, you can reach out to SIMon or create a ticket and a moderator will help you out.
Hope this helps.
Cheers!
11-01-2019 02:39 PM - edited 11-01-2019 02:45 PM
@LoreckAvery wrote:I'm in the states. My phone switched over to t-mobile and I've shut the phone off and on and my texts and data are NOT working! This is frustrating to say the least. Yes it shows the add on under my plan
Have you enabled data and roaming on your phone?
You can also manually select AT&T on your phone, sometimes one carrier gives better reception than the other.
Also if nothing helps you connect then submit a ticket to moderators via SIMon here: https://publicmobile.ca.ada.support/chat/
