Hi,
Does this plan exist forever or does it expire after a certain amount of time?
Thanks
This is how to buy add ons:
To purchase Add-Ons using your Self-Serve account, follow these steps:
@chucker8 wrote:Hi,
Thanks
@chucker8 Nothing is forever...
This is an addon for calling.
It will stay with you until it is all used up.
EDIT:
FYI - you must be in Canada to use this addon.
IF you are in the U.S. you will need the Roaming addon.
@chucker8 I assume your talking about the addon ?
The addon does not expire, It rolls over. It will last untill you use up all the minuites in the addon.
@chucker8 :The 1000 u.s. long distance is add on and will last until you use up those minutes, the $15 plan is only 100 outgoing minutes and free text that renews each month when you prepay again.
is it the Add-on you are talking about? If so, that is a addon that stays on your account until the minutes are used up
Hi,
My balance is $0. When I try to add funds by going to Payment and do a one-time pay, the balance doesn't show up in my funds so I can't pay for the 1000 U.S. Long Distance Minutes - $15.00 plan that I want to purchase.
Check your payment history to see if the transaction to add funds has gone thru. Its best to clear your browser, reboot your phone, use secret/incognito mode in firefox, chrome or safari. Then follow @HALIMACS instructions on how to add funds to your balance. Once successful then go purchase the add on.
