100 Minutes Canada-Wide Talk + Unlimited Incoming plan can not call 519670997 normal Canada number?
jzdst
519-670-997, is a normal Ontario cellphone in the Western University student center. Anybody help me try?
But, when I called it, the system told me: Hi, talk is not included in your plan.
My Plan This plan includes: - - 100 Minutes Canada-Wide Talk + Unlimited Incoming Minutes - 250 MB at 3G speed - Unlimited International Text
$15 per 30 Days
Thank you in advance
edired by computergeek541: phone number removed
15 REPLIES 15
jzdst
Oh, thanks I got your point, maybe the school staff email me a wrong phone number .Thanks
Problem solved
@jzdst wrote:
I tried 1519-670-997, it still does not work
This is not a phone number.
You're missing a digit in the last set of numbers.  "997" needs a 4th number somewhere.
jzdst
Yes, I tried the one with 1: 1519670997, may you try this out of office time to see whether it works? maybe it is the number's problem. Thanks
It's not 10 digits with the 1. That's implied. You need 10 digits as in 3 digit area code, 3 digit prefix and 4 digit unique. Then the 1 in front makes a total of 11 digits being dialed. You're still missing a digit. I suspect your first 6 are right (not counting the 1). The problem is in your last 4. But I don't know what it is of course.
jzdst
Anyone can help me to try this number out of office time to see whether it works in your phone service? Thanks
As mentioned earlier, you are missing a digit. It should have total of 10 digit without the 1 in front (+1 xxx-xxx-xxxx).
jzdst
Thanks,
Mine is :
  • Data & Add-OnsAmount Used
    6  /  100 MIN
    250 MB at 3G speed
    66.725  /  250 MB
jzdst
so what works after you tried it multiple times?
100 minutes can be consumed very quickly...   its billed by the minute 😀
cin7
To add to the other comments, calls are billed by the minute so 100 minutes can be quickly used up if not careful 😉
HALIMACS
Hi @jzdst
If you're on a limited outgoing minute plan, I would login to your self-serve to see if the minute counter appears to have disappeared.  If so, that means you've used your outgoing minute allotment for the cycle.
I would recommend checking that.  It looks like this (below) - check to see if it's there with minutes remaining or not showing at all:
@shubhampatel39 wrote:
Hello,
Try using full number like +1(xxx)xxx-xxx.
Hope this help you.
Well...it wouldn't. You need another digit.
Good of you to jump in and participate.
Welcome to PM.
shubhampatel39
Hello,
Hope this help you.
@Anonymous
I didn't even notice the missing digit (or at first that it's a published phone number).  Public Mobile does give stranged error mesaages. Phone carriers normally give mesaages similar to "call cannot be completed as dialed".
Try it with the missing 10th digit.
