$10 off promo and plan change
twinpuller
Hi, I'm going to Hawaii for a few weeks and want to change to the new $60 plan that has US Roaming. I am currently on the $40 plan but I have the RBC $10 off/month discount. Would I lose this discount if I changed plan?
23 REPLIES 23
lukevader
Yes, it did help the decision, I ported in my wifes # onto that $60 account with the promos kept and just opened a new $25 account with the match price promo on now. Plus with the help of an amaazzzinnggggg mod @Silvio_M here, I'm all setup. Very happy.
Alan_K
@Alan_K wrote:
@lukevader wrote:
@Dunkman  yeah, quite possible it could still be applied. But I even went as far as changing it to apply next billing period and there were no promos listed so I cancelled the change.
So until I get confirmation going the other way from 60 to 40 that the promo will still stick I'll consider it. If it doesn't I'll probably go down to the $15 plan.
Getting back to you asap on this @lukevader ! Hang in there while I get the answer for you Robot wink
@lukevader Sorry for the delay. I've validated with the team and the 5 GB Recurring Add-On will stay, but the $10 off will not. Hope that helps your decision!
Alan_K
@CS_Agent @Alan_K
Could you help confirm with @lukevader his question about if he downgrades his plan to $40 from $60, he will still get the RBC promotion of $10 off for 6 months.  Thanks   Smiley Happy
lukevader
@lukevader
Public mobile wording/warning/etc can be ambigious at times.  @Alan_K (the "boss" moderator/manager) mentioned that in previous post that the discount will still be applied.  I guess if that fails you could contact moderators afterwards.
lukevader
@Dunkman I hear ya, but the change bubble was very clear with before and after promos being applied. And see, thats the thing now, I don't really need this plan anymore... there's a better plan I learned about while down here. More data, more options, even works in mexico and canada.
@lukevader
You should still get the $10 monthly discount for 6 months.  There is usually a warning if you change plans that you might lose different promos.
Just to be aware, the $60 US roaming plan is not available anymore.  If you change plans, you will not be able to get that plan in the future.
lukevader
@Alan_K wrote:
@ShawnC13 Nailed it, a plan change to any plan of $40/mo or greater will not cause the promo to fall off. 🙂
I'm finding an issue with this statement... I am on the $60 plan and still reaping benefits of the USA perks cause I'm still down here as I type this but let's just say I found a deal TOO good to pass up down here to meet my needs for any usa roaming for a while.... soooo I don't really need this $60 plan anymore and the $40 plan will work just fine and when I try to change it, on the confirm changes popup I get a message confirming I will lose all my promotion add ons. The plan is still $40 or more, what's up with this loss of promo?
BrieMusic
Does anyone know if RBC Avion Platinum card qualifies as a "rewards card" for the $10- 6 month discount? I do have rewards when I look at my statement but it doesn't specifically mention that card in the disclaimer posted. Waiting on RBC's answer if they know as well...
twinpuller
**bleep** that's too bad. I'm already in Hawaii and activated a different provider.
 @Alan_K: Once again, mixed or ambiguous messaging between your announcement and the promo details. There shouldn't be different wording and there shouldn't be ambiguity. It just confuses everybody and then wastes *your* time trying to disambiguate it all.
Alan_K
@stonechucker wrote:
@Alan_K, can we assume PM will ensure this language will be in place in future such plans, as the current details are at best, confusing.
Yes absolutely, for future promos I will make a note to add clarity to plan change criteria.
Alan_K
Alan_K
I need to test this but the intended behaviour is you can keep it on a plan change to anything $40/mo or greater. Will loop back to you tmrw!
twinpuller
@ShawnC13 wrote:
@twinpuller wrote:
@GinYVR wrote:
@twinpullerI don't think it is possible https://www.publicmobile.ca/en/on/plans/RBC-offer
Discount will expire if account becomes inactive or the rate plan is changed.
That's unfortunate. Thanks for your response.
@twinpuller, I would question this as it says $40 or greater plan and I think the part that says the discount will expire if account becomes inactive or rate plan is changed is meant to be to a plan lower that $40.  @Alan_K  can you clarify this for this customer.  Am I interpreting this right that only a plan change to under $40 would lose the promo or is it any plan change?  RBC.JPG
Thanks, only problem I see is 2 sentences later it says discount will expire if rate plan is changed. I was hoping to get an answer today but I just went with another provider for my trip. It'll cost me a bit more, but it's ok... hopefully PM will have better roaming add-on rates in the future.
oglat
It wouldn't be the first time when fine print is a bit ambiguous. I also think that they meant if it is changed to cheaper and not to more expensive plan. Can anybody from @CS_Agent check?
popping
The following statement is from the details of this promo.  The promo will expire if rate plan is changed.
YMMV You are changing it to a higher cost plan.  You may be able to keep the $10 credit.  But it is better to check with moderator first. YMMV
 $10 off for 6 months and 5GB one-time data bonus will be applied to eligible Ready-made rate plans of $40/month or greater. Bonus data remains on account until fully used but will expire if account becomes inactive or the rate plan is changed
twinpuller
GinYVR
ShawnC13
Was that promo linked to a specific plan or just had to be over a certain dollar value to receive the $10.  Previous $10 off promos just stated that the plan had to cost more than $XX amount.  I think you would be ok as you are going to a higher priced plan but I can't say for sure as I didn't look into the RBC promo as I was already a customer
