Reply
What phone plans are eligible for the rewards program?
I'm currently on the $25/ MTH plan, but want to change my plan to the $15/MTH plan, however, I can't find anything, anywhere that says which plans specifically are eligible for the rewards program!  So if I downsize my plan will I still be able to use the rewards program?
Re: What phone plans are eligible for the rewards program?
All plans are eligible for the rewards program except for 10 day plans or plans that were made between May 9, 2014 and Jan 26, 2015. So if you go down to a $15 plan, as long as it isn't a 10 day plan you should be eligible for the rewards program.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/General-Reward-Rules/ta-p/164 - Under the "Who can earn rewards"
Thank you so much
All plans for 30 days or more are eligible for the rewards programs.
So yes the $15 plan is eligible for the rewards programs.
