Reply
Highlighted
Password
I have forging password to my account.Twice I entered the reset page but never received an email to reset it? Is there some way to reset the password?
Highlighted
Re: Password
It you can't receive any email to reset your password you need to reach the moderator here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and ask them to help you. Waiting time is few hours to 2 days.
Highlighted
Re: Password
Did you check your Junk/Spam folder just in case the emails are there?
Highlighted
Re: Password
Hi,
I have had this happen before with Koodo, and Public Mobile.  Periodically, there are some delays for the password reset in the system (I put in a request to reset my password around 4pm, I get an email 2:30am the next morning and it is invalid because of the expiry).  My suggestion would be to try it again later in the day if you are not in a rush.  But if you need to change it right away, you can reach out to a moderator to get the password issue resolved.
