Reply
Highlighted
Re: Not able to make call or texts
I still don't how activate my account. Though there is payment made for 2 times today I am not sure why my plan is not active
Highlighted
@nchodid you send a message to the @Moderator_Team yet? They will help you get your plan re-activated.
Highlighted
@ncho wrote:
No I am old public mobile number and changed from a "grandfather" plan to a new one. I have paid as per my account. I still can't receive and make call and texts.
@ncho, how did you make the plan change? Did you login online? If yes, did you select for it to take effect immediately or on the next renewal date?
Highlighted
Check your APN settings are correct. And try turning off your phond and remove your battery and SIM card then wait a minute before putting them back in. Once that's done reboot(startup) your phone.
Highlighted
Do you have peoof
Highlighted
What does APN setting have to do with calling or text?
Highlighted
Everything, your APN settings are what connect you/ your device to your service provider
[Edited by Luddite to strikethrough incorrect information on tihis problem]
Highlighted
Did you change phones or just your plan
Highlighted
I had to wait for a day before mine worked
Highlighted
Try rebooting your phone
