Reply
Change plans
I am on the pioneer plan and have conference calling and call forwarding I was looking at new plans and don't see it listed on new plans does anyone have a new plan and knows if it is included or not?
Re: Change plans
Call forwarding for sure...conference calling???
Re: Change plans
@C7399 Both are included in all plans. You can see what the plans include by clicking on plan Details.
Re: Change plans
Three way calling?
Re: Change plans
@C7399 Three way calling should be included. Conference calling depends on your phone, not the carrier.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/do-the-plans-include-voice-mail-caller-...
Re: Change plans
Thanks but when I did that it wasn't listed there
Re: Change plans
Ok thanks for your help
Re: Change plans
Call forwarding is included all fo the calling plans, but for the ones with lmited minutes will have those minutes used up when forwarding calls.  I've pretty sure that "conference" calling is limited to 3-way (connected to 2 other phone numbers at the same time).  Conference calling is a carrier feature and depends on the number of simultaneous voice call connections that the carrier allows.
