Reply
Highlighted
Canada wide vs Canada long distance on legacy plan
Accepted Solutions
Highlighted
Re: Canada wide vs Canada long distance on legacy plan
If you have Canada-wide calling, the Canadian long distance won't do anything.  Exception: 50 minute plan can use that add on to get more minutes
All Replies
Highlighted
Highlighted
Thanks for the reply l am on a legacy plan with Canada long distance  which comes in handy when  I leave my provinces so if I switch to a Canada wide  plan I will get  the same service therefore I don't need an add on.
  thanks again
Highlighted
That is correct.  You will get the same service and you can use your phone throughout Canada to call any other Canadian phone number.
Highlighted
@paulem, depending on which play you switch to, Canada-Wide is the same price as Province-wide calling (without long distance).  So that's a really good deal.
My plan is Province-wide, from 2016, and I've only used 23 minutes of long distance in 18 months.
