the public sim card does not connect my cell phone.
jamesnicoloff
I am a new user today but the public sim card does not connect my cell phone.  I have three older cell phones.iPhone 4,  Samsung  GT-S5360 and a Motorazr v3.  It doesn't work in any of them.  How do I activate the sim card?  please
11 REPLIES 11
@jamesnicoloff
You had a tech team member from public mobile call you and help you get the sim card to work in your iPhone? Or did an apple team member help You?
If you feel it was public mobiles fault that you couldn't get the sim card to work in your iphone4 then contact the moderators and ask for a credit equal to about one week or 25% of your plan. If your on the $40 plan then ask for a $10 credit or the $15 ask for $3.75. Worst that can happen is they say no.
jamesnicoloff
The apple iPhone 4 is now working fine.
jamesnicoloff
since I had 8 days with no solution even though I asked for help on August 9 I thought I should get a credit or a new start date of August 17, 2020 when a technician in Calgary spent over an hour with me on my landline to try different things until I finally got connected to Public.
@jamesnicoloff
What was the cause of the issue? Which plan are you on?
@jamesnicoloff I don't think asking for a rebate or to move your renewal date or even to get some freebies for your inconvenience is asking too much. Reply to the ticket you were using asking about it.
jamesnicoloff
One of your technical advisers finally solved the problem and as of August 17 I have service.  Can I have a credit for the 8 days I didn't have service?
@gpixel wrote:
@jamesnicoloff these devices are so old.. I know the RAZR v3 and the Samsung do not have the correct frequencies to work with pm. not sure about the iPhone 4
Samsung GT-S5360 is compatible with Public Mobile as it has UMTS bands 2 and 5. The iPhone 4 is also compatible frequency-wise. The only one out of that list that absolutely would not work is the Razr v3.
@gpixel @jamesnicoloff
The iphone4 should work as long as you do the software updates.....is the iphone4 locked to the former provider? Do you know which provider it came from?
gpixel
@jamesnicoloff
What are  the messages you are getting when you put the sim card in each phone? No sim? Sim card error? No sim card detected? Sim card error? Sim card lock?
gblackma
@jamesnicoloff did you activate your SIM card? You have to activate your service before the sim will work.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
