texting pictures on somin xp7
rupe
somin xp7 cel phone All I get is a text message with a 'Download' button to press. When I press the 'Download' button, there is a status bar and and it says 'Downloading'. But it never is able to complete the download.
20 REPLIES 20
 @rupe
The APN name up top should be sp.mb.com
not mp.com
Try browsing to a page first and then try an mms.
Edit: some phones need different things. yes...try the GID and 4D4F
rupe
set to GID?
MNVO Value is it set to 4D4F?
include?
rupe
@rupe one other thing you can try.
For MMS proxy you have -74.49.0.18
For MMS port you have - 80
done still not downloading pictures
Jb456
Try the below setting. Which I just took a screenshot of my phone APN settings that it uses.
Jb456
@rupe
What's your MNVO type?
Is it set to GID?
If not. Set those to that then restart phone.
If they are already set to that. Change them to not set and restart phone.
Also text yourself a MMS picture after you have rebooted your phone. Just text your cell number with an MMS.
rupe
New screen shots
rupe
It is missing /MB/  done
still not downloading?
will restart
Jb456
@rupe
Your link is incorrect on MMSC. You're missing /mb/
This is the correct link that should be in your APN settings.
rupe
MMS" APN Type entered
not working?
Jb456
In your screenshot. Your MMSC link is incorrect.
It is missing /MB/
See picture below it should be like that.
@rupe
rupe
Jb456
@rupe  a screenshot would help but instead on your APN settings under "APN Type" enter all these like picture below.
Save APN settings, reboot and see if you can retrieve the MMS.
Enter the ones on line APN Type
You might be missing "MMS" APN Type. As internet would work but not MMS since it's not on your phone.
Let us know.
rupe
done this
good place to start: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
data turned on your phone  yes
Does browsing the internet work  yes
did restart
still not working
Jb456
@rupe  post a screenshot of your APN settings. You also need to have data turned on your phone. Is it on? Does browsing the internet work? Thanks!
@rupe  could you please post a screesnshot of your APN settings.  Thanks.
rupe
geopublic
@rupe  Data needs to be on in order for MMS to work. Also check your APN settings and make sure it contains MMS as part of the string. If it doesn't then add it at the end
,mms
Don't forget to save your change and try to access the MMS.
Is your mobile data otherwise working?
While the APN settings mentioned a few minutes ago can differ slightly in what needs to be entered on on different devices, here's a good place to start: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
popping
@rupe
Is your data working?
If not, enable date, turn of your phone for 1 minute, restart your phone to let PM SIM card to configure your APN.
Picture message needs data enabled to send and receive picture MMS.
gpixel
@rupe is mobile data enabled? mobile data needs to be enabled to send or receive picture messaging
