switched phone sim card cant acces data anymore
bauness
switched phone inserted new sim card cant acces data anymore, phone call working on network,wifi working
new phone is umidifi F1 verified the band for 3g before buying im on the 30# plan 1gb unlimited call/text
is there a setting somewhere or an information i didnt knew before made the switch?
thank you
english/french answer welcome
bauness
yeah thx forgot about that one when switching phone
ty so much it work
Alex888
Try going into your account, report your phone as lost, log out, wait 5 minutes, log back in and report it found, then restart your phone.
bauness
no  im 497mb/1gb that renew on feb 27 or 29 i think and i switched back to my old phone and data work.. =/
deepropar
Hi,
you may need to check APN settings.
i think APN should be isp.mb.com
Moderator may answer better, but i think fixing APN name will fix the issue
in iphone APN setting is under Cellular>Cellular Data Network
Thanks
thank you
Officially Recognized APN Reference
Or what might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Murco
Is your data expired for the current cycle?
