@saw2165 wrote:thank you i restarted my phone now it works perfect thank you so much
This problem will not happen with old phones with renewable battery and SIM card slot is under battery. In order to change SIM card, battery must be removed to ensure a phone restart.
Nowadays, new phones does not have removable battery and the SIM slot is access from the side. People will continue to have the same problem.
Hello I had the same problem when I signed up, I tried everything and found out it was a bad sim card, if you buy another sim im sure the moderators will reimburse you. Have a nice day
Could be a bad sim card, I had the same problem when i signed up. Try using a different card it should work.
@allpixelated wrote:Could be a bad sim card, I had the same problem when i signed up. Try using a different card it should work.
Fortunately, the member saw2165 has already said that everything is working.
