Reply
Highlighted
Re: phone says no service
Unfortunately seems like you tried all the suggestions that has been provided.
Only thing is to wait for Moderators to respond to you.
Highlighted
How long should it take
Highlighted
24/48 hours they usually respond. However with system issues last few days it might be a bit longer.
Highlighted
@ShaneNelson
Not sure whether you want to try this.  I have seen it used  once or twice in the past in the community forum.
Replace your SIM number, but when you do replace, use the same number as present.  Bascially re-entering your SIM card number.  May "reconnect" your SIM card.  Again, a shot in the dark.  It should do no harm to your plan.  No guarantees that it will work.
Maybe toggle your airplane mode on.  Wait a few minutes.  Then toggle off.
Highlighted
tried it and didnt work
Highlighted
@ShaneNelson
Sorry, you will need to wait for moderators.
Unfortunately, it seems like the waittimes are longer than normal.  Several issues the last few days. Hopefully, moderators will get back to you today sometime.
Highlighted
Still does not work and still have not heard from anyone has now been 48 hrs. tbis is horrible customer service
Highlighted
@ShaneNelson  Unfortunately you will have to wait from a response from the moderator because more than likely your account was not provisioned properly and they will have to reset it from their end.
Highlighted
But i have been paying for service for 3 days yet have no service this is wrong
Highlighted
@ShaneNelson  PM should credit your account for the 3 days or ask them to change your renewal by whatever the amount of days it takes to fix.
