Reply
number already registered
Tried registring a new account, but when I enter my phone number the response is taht my number already registerd with my email and I have not registered my phone number at anytime.
Re: number already registered
@frankfrank, Did you sign up with a retailer (such as Walmart, Wow mobile, etc)?  Perhaps they set up your self serve account for you?
Is this when you are activating a new sim and it asks you to select a new number or port over an existing one?
And also it says your email address is in use?
Did you have any activation errors come up before this?  If yrs maybe the sim git activated already? Did you try using it?
No, I just heard of this network two days ago
Easiest solution..
Go to Gmail, create a new email, use it. Solved. Use you browser to log into it at mail Google.com
Yes, you can get it checked out, but it will take time.
PM never seems to use that email except for the initial check
If you need more details/guidance than the above you can send me a personal message
Are you by chance with koodo prepaid? They share the same backend
Did you create a self-serve account of a community account?
I had issues registering because activating my SIM card didn't create an account and my community account wasn't attacked to my phone. Try loging out then go to "My Account" and click "create an account", it should prompt you to enter your phone number then you can create a self-serve account.
