just activated my new sim but incoming calls not coming
kantidinesh
22 REPLIES 22
kantidinesh
Thanks a lot.it was indeed a great help
If my answer has helped, please accept as solution
kantidinesh
Thanks.its working now.
@kantidinesh Step by step directions for setting APN can be found here: http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartph...
Go to settings, then look for more..., click, then look for cellular networks, and see Access Point Names
kantidinesh
how to go to apn settings
Ougoing but no incoming calls is normal behaviour when you first make the port in request. If this is the situation, just wait a few hours for it to complete; it is dependent on virgin tech support. You can try putting the virgin sim back in and see what happens.
BTW if you cancelled your virgin account before the port in completed that number is lost.
kantidinesh
As of now its on telus network.
outgoing is possible
incoming is no happening.
Mobile data is not working
If you don't do this, MMS and Data access Just won't work
Also, DON'T forget to do this:
Here's another set, MUCH MORE detailed:
Welcome to Public Mobile
Enjoy
OK
Maybe Porting Activation is in process
Sometimes, it takes longer. Normally its Fast, like Instantaneous fast, rarely does it take like 30 min or 1 hr or more
kantidinesh
its a 4G compatiable phone.its recognising telus network but not able to get incoming calls only.outgoing is possible now
Plus, India may not share the SAME spectrum as NA Carriers
Basically, Buyer Beware
Public Mobile's IMEI reader is NOT reliable
Has tendency to give out False Positive readings
If your Phone lacks any of these spectrum frequencies, Handset will not function
kantidinesh
in india.i checked the IMEI no before porting.it said my mobile is compatiable
Telus/Koodo/PM
HSPA+4G Network Frequency Spectrum:
3G:  850/1900 MHZ
3G is the BARE MINIMUM REQUIREMENT for Talk + Text + Data
4G LTE:  1700/2100 MHZ
Some Phones might NOT be able to do Talk while on LTE, So depending on your device, go into your settings,  look for more, click, then look for Cellular Networks, Click, then look for Preferred Network Type, That's where you can choose between your 3G and 4G LTE settings
4G LTE Advanced:  700 MHZ
(Note: This specific Frequency is currently UNAVAILABLE, Currently being assembled; Also ONLY devices with THIS Built-In WILL be able to take full advantage of THIS; OLDER devices Will NOT Work on THIS
If you choose to bring your own phone, MAKE sure That it has these frequencies, and ALSO Unlocked.
Where did you purchase phone from?
kantidinesh
Its a unlocked phone.Its brand new.its not assosiated to any carrier.
regards
DID YOU UNLOCK that PHONE? IF NOT, that's why it's NOT working
kantidinesh
Hi
I just activated half an hour back and my previous cariier was virgin.i am using samsung Note 4.
kindly advise
thanks
dinesh
makkahn28
Hi. What handset are you using?
Also, when did you activate new account? did you port your # from previous carrier, or choose a New #?
