Reply
Highlighted
issues with picture texting
hey
my pictures arent being sent.
Accepted Solutions
Highlighted
Re: issues with picture texting
@Icyprincess wrote:
hey
@Icyprincess  Data needs to be on and make sure that your APN setting for APN Type contains mms in your string.
All Replies
Highlighted
You need data to send pictures so check if your data is on.Also try logging into your account and check usage make sure you have data availale.that is if you have a data plan. Is it an iphone or android?
Highlighted
@Icyprincess You need to set your wifi or data on.
Highlighted
@Icyprincess wrote:
hey
Highlighted
MMS doesn't send through Wi-Fi.
Highlighted
Thank you all
