11-14-2019 12:52 PM - edited 01-05-2022 07:59 AM
11-15-2019 11:58 AM
@gerriwalsh wrote:Sorry I dont understand anything of what you said does that mean i can use samsung A30 A305G on Public Mobile or not?? Thankks I am a bit of a Techodinosaur
@gerriwalsh it will be fine for calls and texting and 3G data. You may not get the newer 4G LTE coverage in some areas as it lacks the "main" 4G band (band 4) used by Public Mobile, but you will be able to use it fine anyway. You should not need to return the phone.
11-15-2019 01:01 AM
It should be 🙂 you can always check the website for compatibility
11-14-2019 05:46 PM - edited 11-15-2019 01:02 AM
@gerriwalsh Return it. Good phones choices for you would be.
Nokia 7.2 or 6.2
Motorola One Action
Umidigi F2
11-14-2019 04:39 PM
The phone has been ordered and shipped as of today should i keep it or return it?
if i use it as per your advise what problems would i incurr?
11-14-2019 03:34 PM - edited 11-14-2019 05:58 PM
@gerriwalsh If you already have the phone then yes you can use it with Public Mobile. If you are thinking of buying it then maybe you should consider something else.
11-14-2019 03:28 PM
11-14-2019 01:12 PM - edited 11-14-2019 01:14 PM
According to sammobile.com, this dual SIM phone supports the following bands for PM:
https://www.sammobile.com/samsung/galaxy-a30/specs/SM-A305G/
This phone is missing LTE 1700 AWS. Depending on the location, you may not get LTE support.
11-14-2019 01:05 PM - edited 11-14-2019 01:07 PM
@gerriwalsh Not a good choice as it only supports the 3G bands and only B5 and B7 of the 4G/LTE bands. You are better off going with another option.
11-14-2019 12:57 PM
It should be compatiable if it supports 850 and 1900 bands.
11-14-2019 12:54 PM
It should be compatible
