10-04-2021 10:04 PM - edited 01-06-2022 03:41 AM
hi there!
i tried everything, i changed the apn settings with the ones on PM website, I even copied these settings from another motorola cellphone, still does not work. Any advice?
thanks!
10-04-2021 11:09 PM
look like you are on 4g, you can change it back to 3G ?
10-04-2021 11:07 PM - edited 10-04-2021 11:10 PM
still does not work, the data icon looks like this but instead of 4G is H+
it has that little x, but the mobile data is on...
updated: if I turn the wifi on then the X disappears, then re-appears when WIFI is off
10-04-2021 10:50 PM
this is how to reset network setting on a Moto phone
10-04-2021 10:46 PM
If it doesn't work, the worst case is you might have to buy a North American phone.
10-04-2021 10:45 PM
new to PM, new sim, new phone
how to reset network?
the Data icon on top right corner shows coverage and H
10-04-2021 10:42 PM
@nicoldans Have you enabled data on and set the network to 3G HSPA only?
10-04-2021 10:42 PM
@nicoldans leave it with 3G Only, try a network reset and see how it goes
BTW, just to confirm, are you new to PM or you have been with PM for some time and just got a new phone? If you are new to PM, you might want to test you SIM on another phone just to confirm the account was provisioned properly. Just in case ..
10-04-2021 10:40 PM
@nicoldans Given your phone has the bands for 3G network, it should work on PM but on the 3G HSPA network only, you can't access LTE because the LTE bands are not compatible with your phone.
10-04-2021 10:40 PM
no 😐
10-04-2021 10:39 PM
@nicoldans wrote:i did this from your first reply 🙂
Try to set the network to 3G Only and see if you are getting some data traffic out of it.
so it works?
10-04-2021 10:38 PM
10-04-2021 10:35 PM
@nicoldans wrote:ok found it, here is my model number and compatibility:
it should work or not really?
@nicoldans it looks like yours is a Global version, from kimovil, you have both 3G bands, which is good. But you only have 2 compatible 4G bands, which could be an issue
Will Motorola Moto E7 Power work in Canada? (kimovil.com)
10-04-2021 10:31 PM
@nicoldans wrote:by comparing the bands used by the cell and PM there are some frequencies that are common...
how can i see what type of cell I have? it's a Moto e(7) power but i see there are several ...sub-models...:(
Where did you buy this phone?
What exact model number you have? check the label on th box, or check from Setting->About phone
10-04-2021 10:30 PM
10-04-2021 10:26 PM
10-04-2021 10:17 PM - edited 10-04-2021 10:18 PM
@nicoldans wrote:
@nicoldans Yes, I think at the moment, it is more to do with your phone not having the proper bands. In your case, you should have better result with 3G only. With your lack of 4G bands, you will not have good LTE connection everywhere
10-04-2021 10:16 PM
Try setting your network to 3G and make sure cellular data setting is turned on.
10-04-2021 10:12 PM
10-04-2021 10:08 PM - edited 10-04-2021 10:14 PM
@nicoldansWhat variant is your Moto e7 power? It looks like both the Global version and the Indian version might not work on PM too well. These versions only have 2 bands compatible with PM (B5 and B7). The only better variant is the Brazil version, which has 4 compatible bands (B2, B4, B5 and B7). Which variant you have?
Try changing to 3G only , the phone has both B2 and B5 for 3G, which might work better.
FYI, phone should ideally have 3G B2, B5 and LTE B4 (or B66 instead of B4), B12 (or B17 instead of B12) for minimum coverage.
If your phone does not have all recommended bands, you may have poor coverage / no service / slow data in some locations.
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
HSPA: 850 MHz, 1900 MHz (UMTS).
4G = B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
3G = B2(1900) B5 (850)
10-04-2021 10:06 PM - edited 10-04-2021 10:08 PM
@nicoldans wrote:hi there!
thanks!
Have you checked your account to see if you have available data?
What shows under Plans & Add-ons on the overview page?
