Reply
iPhone 5 - SIM card not supported
I setup my account and activated my SIM card yesterday and was met with the following error:
"The SIM card you currently have installed in this iPhone is from a carrier that is not supported under the activation policy that is currently assigned by the activation server.
Please insert another SIM card from a supported carrier or request that this iPhone be unlocked by your carrier"
  • My phone is unlocked, it was bought outright.
  • It is not attached to another other carrier at this moment.
  • Public Mobile is showing under General > About >Carrier: Public Mobile 28.3.
  • If I put in an old SIM card from PC mobile it works. But when I switch it out back to Public Mobile, I am met with that error.
Re: iPhone 5 - SIM card not supported
To make sure your sim is good and if it was successfully activated, try it in other unlocked phone and see if it works. If it does, something is wrong with your iPhone 5.
_________________________________________________________________________
If you need to contact PM, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
Additional ideas:
a) reboot the phone
b) did you request a port-in of your PC Mobile number?
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
@inked_koi Just occurred to me: where did you buy the phone?
Real quick search but I've read:
  • Some unlocked iPhones will lock themselves to the first SIM's network inserted - seems to depend on where exactly the phone was purchased from ie. purchased directly from Apple, directly from carrier, etc.
  • You must sync with iTunes before changing SIMs
As usual, lots of "no it doesn't, that's wrong, worked for me, etc" so just throwing these out there.
Are you able to check your PM SIM in another unlocked phone? Or a non-PM, non-PC Mobile SIM in your iPhone?
Your phone is locked.
You may have bought your phone outright, but for whatever reason, your phone is locked to a carrier other than Telus.  It's possible that there's some type of error in Apple's database, but as it stands now, your phone is not unlocked - sorry.  The lock is likely to Bell as you mentioned PC Mobile earlier (PC Mobile has both Bell or Telus services depending on prepaid/postpaid).   You will have to get the phone unlocked before you can use it on Public Mobile.
Fortunately, carriers in Canada unlock phones for free now.
If you purchased this phone as factory unlocked directly from Apple, contact Apple to get this rectified.  If you purcahsed this phone as a Bell device (whether outright or not), from either Apple or a Bell retailer/authorized dealer, contact Bell Mobility to get this device unlocked.
my iphone not supported sim card
how to open my phone
Sounds like your phone maybe locked.  Did you switch from another provider ?  if so then you would need to contact them to unlock it.
