Reply
philipcrwood
help
i just had my phone hooked up and went into the text messege options i changed the number that was there to my number and now my phone wont work for texts
Jb456
Re: help
When you joined. Did you select a brand new number or did you port a number from your old provider?
If you ported, from what company and when?
What is the make and model of your phone?
When sim card is in does it connect to PM network?
Does anything work at all? Call in/out, text in/out, data?
Have you tried rebooting phone? What have you tried and what have you done?
z10user4
Re: help
 @Jb456
Are your ears ringing from the loudness of the crickets? 🙂
Jb456
Re: help
@z10user4 tell me about it.. chirp chirp 🦗🦗🦗😆 making my work night go slow lol
z10user4
Re: help
Figures. Just as I made the post about the crickets from this OP...other threads pop up. So yeah...crickets from this thread 🙂
gpixel4
Re: help
@philipcrwood what's the make and model of the device?
try resetting your network settings
gblackma
Re: help
@philipcrwood it's your 10 digit PM phone number change it back. And restart your phone. Stay safe.
Re: help
@philipcrwood The SMSC setting being incorrect will prevent you from sending outgoing text messages. This is not supposed to be set to you own number. It should be set to +16475800172.
Re: help
In the first post, philipcrwood stated that the number was changed to the Public Mobile phone number. That's what caused the problem/when the probelm started.
