data plan not working
dboxtvinfo715
I changed phone now my mobile data is not working ,
9 REPLIES 9
k1m
Thanks for the greeting! This looks like a very helpful community.
mimmo
@k1m  welcome to PM.  yes many answers can be found in the forums.  its great to see you were able to fix your issue.
k1m
I’m a new PM member and couldn’t get my data working until I read this post. Now I have data... and I feel techy, though I’m not really. You grew my confidence. Many thanks!
k1m
I am a new PM member with an LG phone, and this extra bit of info was so useful. Now I have data.
Thanks!
slayerH
For me I had to change MVNO type: GID to none
And put spaces after , like this: default, mms, agps, supl, fota, hipri
Thanks for your info!!
dboxtvinfo715
so far my attempts haven't worked, found network but VPN,       issue input confusion
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
popping
@dboxtvinfo715 wrote:
Will probably go too kiosk and thhanks for the bravo. I think its too complicated for me now too adventure vpn settings.  for now
Do a quick test first before going to Kiosk.
Enable data. Restart your phone to let system configure your APN automatically.
If you have a LG phone, you need to perform a network reset after changing provider before your data working again.
dboxtvinfo715
geopublic
@dboxtvinfo715Make sure data is turned on and also check to make sure you have the correct APN setting. This is the Public Mobile APN setting that you will need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
Don't forget to save these settings and then select this APN as the active one.
