Reply
Highlighted
call ID
how to have my phone number and name appear on the phone that receives mt call?
Accepted Solutions
Highlighted
Re: call ID
Who was your last provider? Was it Roger's? I think they are the main company with name display.
Edit: this is from the Roger's website
Not really sure if PM fully supports this feature. Am thinking not.
Name Display is a feature that allows you to see both a caller's name and number. This feature is different from Call Display, which simply displays a caller's number.
Keep in mind: If you've already added the caller to your phone's Contacts list, the name you stored on your phone will display, along with their number.
All Replies
Highlighted
Re: call ID
The receiver's phone would need to subscribe to call display with their provider.
Highlighted
Re: call ID
Also make your phone SETTINGS are set to SHOW your number  (and NOT) block them..
Highlighted
Re: call ID
@wang01_99  are you talking about caller ID or name display?
Caller ID the receiver needs to have you stored on contacts.
For name display your name will appear instead of unknown number. This is carrier dependant feature.
Highlighted
Re: call ID
Thank. WHat I want to do is if I call you, I want my name and phone number appear on your phone display such that you know it is me.
Highlighted
Re: call ID
Make sure YOUR caller ID is ON,   on your phone, and not turned off.   Check  under settings on your phone.
Highlighted
Re: call ID
This should be straightforward.  The feature is self contained in the phone.  If you have your contact list loaded in the phone receiving the call, the phone will look up the number from the contact list and display the name of the caller as it was entered in the contract list.
Highlighted
Re: call ID
Thanks. I have my home phone number in the contact list. I call it from my cellphone, the cellphone number appears on the home phone display but without my name. This same occurs when I call my friends. However, before I changed to Public Mobile a week ago, my name and cellphone number did appear on the receiver's phone display. Any idea how to set it up on my cellphone?
Highlighted
Re: call ID
The call receiver has to have that feature to show name and number.   That is a payed service that the call reciever has to have on their phone.        Just make sure that your caller ID is turned ON on your phone.  Look under settings  (for your phone).
Highlighted
Re: call ID
Was your last cell phone carrier the SAME as your current home phone supplier (landline).
