Wrong SIM Card, card too wide, pins on Telus card on edge, PM card pins not on edge
BandB
Received a Public Mobile SIM card. Phone is Samsung Galaxy S5, model SM-G900W8
Telue sim ard has all pins on top edge of sim ard
PM sim card too wide for sim slot and the pins cover the whole bottom of the card
Need to talk to tech support.
14 REPLIES 14
Jb456
@BandB wrote:
Thanks
Finally realised the Public Mobile SIM card is under the Micro SD memory card,
Phone working
Thx
Great. Welcome to Public Mobile 🙂
BandB
Thanks
Phone working
Thx
@BandB  This is what a regular size telus sim card looks like...20191229_070733.jpg
Jb456
Here is where sim goes in you S5
@BandB  That's not a telus SIM that's a micro sd card. Same size and it will fit in a SIM card slot.
Jb456
The picture you posted showing Telus sim..it is not the sim card. That is an SD card which likely was in your phone to add more memory.
BandB
SIM card from Public Mobielo , wrong configuration
GR
@BandB wrote:
Only received the Standard card, the one in the image above with the scarf around the card.
Pins like           P    P    P
                        P    P    |
Telus card is          |----------------|
                              |PPPPPPPP|
                              |__________|
@BandB that looks like a SD  card to save pictures and stuff!
@BandB  Can it not snap away from the housing to the size you need? You would want the nano size to stay in the micro frame. 2 pieces rather than the three shown.
Regular, micro,nano.
@BandB  Where did you get your card from? It doesn't have the ability to gently snap the smaller sizes out?
BandB
Pins like           P    P    P
                        P    P    |
                              |PPPPPPPP|
                              |__________|
@BandB  Your S5 takes a micro SIM card. That is the middle sized SIM or the dark orange one in the above diagram.
Jb456
Does it look like below? Should be 3 s cards in one.41Uv5BcQ49L._AC_SY400_ML2_.jpg
