Reply
Dijinero367
Will my phone work with Public Mobile SIM?
I need to port on PM from Chatr... I checked, but my Samsung galaxy A10s is not part of the list of compatible mobiles mentioned on website. Can someone confirm if my Samsung galaxy A10s model number SM-A107M is compatible or not??
z10user4
Re: Will my phone work with Public Mobile SIM?
It'll be fine. I looked at that model too but it doesn't have NFC so I passed.
Triguy
It should be compatible.  Make sure it is unlocked.
geopublic
@Dijinero367  Your device will work. As for porting from CHATR be sure to note the best practices below to ensure a smooth process:
    • Only the authorized account holder can transfer a number.
    • You cannot transfer numbers between Public Mobile accounts.
    • Your previous account must be active in order for the number transfer to go through. Once the transfer is complete, it will be automatically deactivated from your previous service provider.
    • Double check your old account info, as it needs to be correct in order for your number transfer to complete.
    • Here’s the information you’ll need: CHATR account number, name on the account and CHATR phone number
It is recommend porting your number during activation by providing the above info.
Hope this helps.
