I am looking at a new cellphone. Moto G6 XT1925-2 does not show up on the compatability table. Does that mean it will not work with Public Mobile?
@Bhansen , According to this answer here, it will work .https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Is-Motorola-G6-supported/m-p/404578/h...
@Bhansen wrote:I am looking at a new cellphone. Moto G6 XT1925-2 does not show up on the compatability table. Does that mean it will not work with Public Mobile?
If a single-sim device is all you need, you'd be better off with the XT1925-6 as that is the version designed for use in Canada.
It should be compatiable if it is the North Amerian version and unlocked.
You might also consider something like this. It's running Android 10 and a great buy at $130.
@Bhansen, yes it should work fine.
3G - UMTS B1(2100), B2(1900), B4(1700/2100), B5(850), B8(900)
4G - LTE B1(2100), B2 (1900), B3 (1800), B4 (1700/2100) , B5 (850), B7 (2600), B12 (lower 700 ac), B17 (lower 700bc), B28 (700 APT)
