04-22-2020 11:19 AM - edited 01-05-2022 10:28 AM
04-22-2020 11:39 AM
@JK8 according to this site it's 100% compatible
https://www.frequencycheck.com/compatibility/2Bqeu4j/nokia-8-global-td-lte/canada
Here's 4 articles on activation and porting and the Refer a friend reward if required:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Welcome to PM. Stay safe.
04-22-2020 11:38 AM
@JK8 From what I can see, yes, it will work with PM. However, it should be unlocked.
04-22-2020 11:24 AM - edited 04-22-2020 11:25 AM
To check if a phone is compatible with Public Mobile use this website
As the carrier put public mobile and input the make and model of your phone. Remember your phone needs to be unlocked from your previous carrier if not already unlocked for it to accept a PM SIM
