05-05-2020 02:31 PM - edited 01-05-2022 10:40 AM
Hi,
I have poor cell reception at my house. I currently have an iphone5s. Does anyone know if getting a newer iphone would help with the reception? or is there a phone that gets better reception? Thanks!
12-18-2021 02:18 PM
iOS updates are over for SE and downwards although it does hurt to pick up any missed ones.
12-18-2021 02:12 PM
Hi @Islandgirl56 I am surprise an iPhone 6 would make a huge difference from iPhone 5.. Since you have a new phone now, try to factory reset you old one , update the OS and maybe it will perfect better
12-18-2021 02:12 PM
Nice!!
Check here for proximity of closest Bell or Telus tower.
We have had iPhone 4S, SE and 8 plus. Not much difference.
Sometimes you have to find best spot in residence. Or out on the street...brrrrrr..
And of course do a walk about and check how many bars you have.
12-18-2021 02:05 PM
Just an update - I got a newer iphone (iphone 6) and now have much better reception, so I guess the answer to the original question is YES!!!!!
05-07-2020 04:18 PM
@DryWater oh that's an interesting idea. I will look for an iphone app like that. Thanks.
05-07-2020 03:46 PM
@Islandgirl56 You're welcome. I'm not sure if an app like this exists for your iPhone, but with my Android phone I use an app called "Phone Signal" which can plot a chart of how strong the signal is. It's very helpful in troubleshooting as you don't have to rely on guesswork or the signal meter on your phone. It can help identify "dead zones" where the signal is poor, and it can also tell you how many cell towers my phone sees. If you have an app like that available, it'd be interesting to see what your results are.
05-07-2020 03:39 PM
@DryWater Thanks for the tip. I've already tried that, i'm not sure if it's helped having it out of the case all that much.
05-07-2020 01:58 PM
@Islandgirl56 One other thing to consider if you have a case for your phone is to see if removing the case improves your reception. Most cases should NOT interfere, but some can and it may be worth eliminating that as a possible source of your poor reception.
For what it's worth, I'm able to make calls in my basement with my Samsung Galaxy Note 10+ (in a TPU case) without any drops or voice degradation.
Good luck!
05-06-2020 11:22 AM - edited 05-06-2020 11:23 AM
There are no data charges to run up here. You just consume your data.
Public Mobile uses "3G" for voice.
05-06-2020 10:32 AM - edited 05-06-2020 10:34 AM
@gpixel The LTE toggle is under cellular data and my cellular data is turned off as I don't want to run up my data charges. I don't understand how switching off the LTE there would help with my phone reception.
05-06-2020 12:35 AM - edited 05-06-2020 12:37 AM
@Islandgirl56 goto settings>cellular and you should see it in there. look for a 4g toggle or LTE and turn it off.
05-06-2020 12:34 AM
@Islandgirl56
Newer phones can tap into more and faster spectrums. Some of the newest spectrums can operate up to four times better inside buildings as opposed to older spectrums
05-06-2020 12:21 AM
@Islandgirl56 it may help, I found thia answer on reddit,
"Reception may improve due to the new phone supporting more bands and aggregation and having newer more efficient antenna designs"
Cheers
05-06-2020 12:20 AM
@Islandgirl56 what iOS version are you using?
05-06-2020 12:16 AM - edited 05-06-2020 12:17 AM
@gpixelI can't find the options you've described to switch to HSPA
05-05-2020 03:28 PM
@Islandgirl56 wrote:@gpixelare there any drawbacks to doing that?
None, unless LTE is better where you are.
05-05-2020 03:04 PM
05-05-2020 02:54 PM - edited 05-05-2020 02:59 PM
@Islandgirl56 try switching from LTE to HSPA. maybe you'll have better reception.
1.goto settings>mobile data>mobile data options
2.select voice data options
3.select 3g
05-05-2020 02:46 PM
@gblackmalol. It's mostly annoying when texting.
05-05-2020 02:40 PM
@Islandgirl56 in the meantime just use your phone in the places with the best reception in your home. Try the "can you hear me now" method of elimination. 😁.
05-05-2020 02:37 PM
@gpixel Yeah trying anoth phone with my sim is a good idea, maybe not right now with covid, but worth a try at some point.
05-05-2020 02:35 PM - edited 05-05-2020 02:36 PM
@Islandgirl56 the best test to do would be to put your sim in a friend's newer iPhone and see what the reception is like. granted their phone is unlocked.
05-05-2020 02:34 PM
Reception elsewhere is generally good.
05-05-2020 02:33 PM
@Islandgirl56 how's the reception elsewhere? Thanks.
05-05-2020 02:32 PM - edited 05-05-2020 02:34 PM
@Islandgirl56 it could help.. newer phones have better antennas. more frequencies. there are no guarantees that you will get better reception especially if you live in brick walls, underground.
